Какие турбины на каких Эво стоят в стоке
Сообщение Dimarik » 04 авг 2012, 12:23
Многие спрашивают и ищут инфу - что и где стоит в стоке
Вот нашёл инфу
Evo I-X stock Turbocharger Specs
Evolution 1
Turbo = TDO5H-16G-7
p/n = 49168-01450
Nozzle Area (cm2) = 7
TD05H turbine = Inconel (steel alloy)
Compressor = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Evolution 2
Turbo = TDO5H-16G-7
p/n = 49168-01450
Inducer = 48.3mm
Exducer = 68mm
Evolution 3
Turbo = TD05H-16G6-7
p/n = 49178-01470
Inducer = 48.3mm
Exducer = 68mm
Reverse rotation turbos and twin scroll turbine housing from EVO4.
Evolution 4
Turbo = TD05HR-16G6-9T
p/n = 49178-01510
Nozzle Area (cm2) = 9
TD05HR turbine = Inconel (steel alloy)
Compressor 16G6 = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
p/n = 49178-01520
Turbo = TD05HRA-16G6-10.5T (RS)
p/n = ?
Nozzle Area (cm2) = 10.5
TD05HR turbine = GSR Inconel (steel alloy)
TD05HRA turbine = RS Titanium alloy
Inducer = 48.3mm
Exducer = 68mm
Evolution 6
p/n = 49178-01550
Turbo = TD05HRA-16G6-10.5T (RS/RS2)
p/n = 49178-01560
TD05HR turbine = GSR - Inconel (steel alloy)
Inducer = 48.3mm
Exducer = 68mm
Evolution 6.5 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
p/n = 49178-01570
Turbo = TD05HRA-16G6-10.5T (RS/RS2) (Note: OZ TME)
p/n = 49178-01560
TD05HRA turbine = Titanium alloy for both RS/RS2/GSR!
Inducer = 48.3mm
Exducer = 68mm
Compressor 15GK2 = Aluminium
Inducer = 49.3mm
Exducer = 65mm
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
p/n = 49178-01570
Turbo = TD05HRA-16G6-9.8T (RS/RS2)
p/n = 49178-01580
Nozzle Area (cm2) = 9.8
TD05HRA turbine = RS/RS2 = Titanium alloy
Inducer = 48.3mm
Exducer = 68mm
Evolution 7 GTA
Turbo = TD05HR-15GK2-9.0T
p/n = 49378-01500
Nozzle Area (cm2) = 9.0
TD05 Turbine = Inconel (steel alloy)
Inducer = 49.3mm
Exducer = 65mm
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM / ADM)
p/n = 49378-01520 (twin flapper)
Turbo = TD05HRA-16G6-9.8T (RS/RS2 & NZDM)
p/n = 49378-01510
p/n = 49378-01540 (ADM EVO8 single flapper)
TD05HR turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
TD05HRA turbine = RS Titanium alloy.
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper USDM
Evolution 8MR aka "8.5"
TD05HR-16G6-10.5T
p/n = 49378-01560
TD05HRA-16G6-10.5T (Ti Alloy option)
p/n = 49378-01550
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = single flapper
Evolution 9
p/n = 49378-01580
Turbo = TD05HRA-16G6mC-10.5T (RS)
p/n = 49378-01571
p/n = 49378-01570
TD05HR turbine GSR = Inconel (steel alloy),
TD05HRA turbine RS = Titanium alloy
Compressor 16G6 = Aluminium (GSR)
Inducer = 48.3mm
Exducer = 68mm
Compressor 16G6mC = Magnesium (RS)
Inducer = 48.3mm
Exducer = 68mm
Back to "normal" rotation turbos from EVOX.
Evolution X
Turbo = TD05H-152G6-12T (GSR)
p/n = 49378-01640
p/n = 49378-01641
Turbo = TD05HA-152G6-12T (GSR)
p/n = 49378-01631 (Ti Alloy)
Nozzle Area (cm2) = 12
TD05HA turbine = Titanium alloy
Compressor 152G6 = Aluminium
Inducer = 47mm
Exducer = 68mm
NOTE: TD05H & TD05HR & TD05HRA turbine wheel all models
Inducer = 56mm
Exducer = 49.2mm
Re: Какие турбины на каких Эво стоят в стоке
Сообщение 4g64 » 20 фев 2016, 20:30
Верю. Сил 40
эво8 2.2 hks3240 aem
4g64
Благодарил (а): 3 раз.
Сообщение t527rus » 21 фев 2016, 05:24
Костя,да не будет там 40 сил разницы.Максимум сил 10-15,за счет чуть большей компрессорной улитки,т.е. эти крохи отыграются только за счет температуры в компрессоре.А воздуха у них одинаково мало).За двушку не скажу,но на 2,4 воздуха после 5500 нет ни у той,ни у другой).И по расходомеру цифры плюс-минус ровно.
Пред.
