Какие турбины на каких Эво стоят в стоке
• Страница 1 из 3 • 1, 2, 3
Многие спрашивают и ищут инфу - что и где стоит в стоке
Вот нашёл инфу
Evo I-X stock Turbocharger Specs
Evolution 1
Turbo = TDO5H-16G-7
p/n = 49168-01450
Nozzle Area (cm2) = 7
TD05H turbine = Inconel (steel alloy)
Compressor = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Evolution 2
Turbo = TDO5H-16G-7
p/n = 49168-01450
Inducer = 48.3mm
Exducer = 68mm
Evolution 3
Turbo = TD05H-16G6-7
p/n = 49178-01470
Inducer = 48.3mm
Exducer = 68mm
Reverse rotation turbos and twin scroll turbine housing from EVO4.
Evolution 4
Turbo = TD05HR-16G6-9T
p/n = 49178-01510
Nozzle Area (cm2) = 9
TD05HR turbine = Inconel (steel alloy)
Compressor 16G6 = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
p/n = 49178-01520
Turbo = TD05HRA-16G6-10.5T (RS)
p/n = ?
Nozzle Area (cm2) = 10.5
TD05HR turbine = GSR Inconel (steel alloy)
TD05HRA turbine = RS Titanium alloy
Inducer = 48.3mm
Exducer = 68mm
Evolution 6
p/n = 49178-01550
Turbo = TD05HRA-16G6-10.5T (RS/RS2)
p/n = 49178-01560
TD05HR turbine = GSR - Inconel (steel alloy)
Inducer = 48.3mm
Exducer = 68mm
Evolution 6.5 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
p/n = 49178-01570
Turbo = TD05HRA-16G6-10.5T (RS/RS2) (Note: OZ TME)
p/n = 49178-01560
TD05HRA turbine = Titanium alloy for both RS/RS2/GSR!
Inducer = 48.3mm
Exducer = 68mm
Compressor 15GK2 = Aluminium
Inducer = 49.3mm
Exducer = 65mm
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
p/n = 49178-01570
Turbo = TD05HRA-16G6-9.8T (RS/RS2)
p/n = 49178-01580
Nozzle Area (cm2) = 9.8
TD05HRA turbine = RS/RS2 = Titanium alloy
Inducer = 48.3mm
Exducer = 68mm
Evolution 7 GTA
Turbo = TD05HR-15GK2-9.0T
p/n = 49378-01500
Nozzle Area (cm2) = 9.0
TD05 Turbine = Inconel (steel alloy)
Inducer = 49.3mm
Exducer = 65mm
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM / ADM)
p/n = 49378-01520 (twin flapper)
Turbo = TD05HRA-16G6-9.8T (RS/RS2 & NZDM)
p/n = 49378-01510
p/n = 49378-01540 (ADM EVO8 single flapper)
TD05HR turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
TD05HRA turbine = RS Titanium alloy.
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper USDM
Evolution 8MR aka "8.5"
TD05HR-16G6-10.5T
p/n = 49378-01560
TD05HRA-16G6-10.5T (Ti Alloy option)
p/n = 49378-01550
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = single flapper
Evolution 9
p/n = 49378-01580
Turbo = TD05HRA-16G6mC-10.5T (RS)
p/n = 49378-01571
p/n = 49378-01570
TD05HR turbine GSR = Inconel (steel alloy),
TD05HRA turbine RS = Titanium alloy
Compressor 16G6 = Aluminium (GSR)
Inducer = 48.3mm
Exducer = 68mm
Compressor 16G6mC = Magnesium (RS)
Inducer = 48.3mm
Exducer = 68mm
Back to "normal" rotation turbos from EVOX.
Evolution X
Turbo = TD05H-152G6-12T (GSR)
p/n = 49378-01640
p/n = 49378-01641
Turbo = TD05HA-152G6-12T (GSR)
p/n = 49378-01631 (Ti Alloy)
Nozzle Area (cm2) = 12
TD05HA turbine = Titanium alloy
Compressor 152G6 = Aluminium
Inducer = 47mm
Exducer = 68mm
NOTE: TD05H & TD05HR & TD05HRA turbine wheel all models
Inducer = 56mm
Exducer = 49.2mm
Вот нашёл инфу
Evolution 1
Turbo = TDO5H-16G-7
p/n = 49168-01450
Inducer = 48.3mm
Exducer = 68mm
Evolution 2
Turbo = TDO5H-16G-7
p/n = 49168-01450
Inducer = 48.3mm
Exducer = 68mm
Evolution 3
p/n = 49178-01470
Inducer = 48.3mm
Exducer = 68mm
Evolution 4
p/n = 49178-01510
Inducer = 48.3mm
Exducer = 68mm
Evolution 5
p/n = 49178-01520
p/n = ?
Inducer = 48.3mm
Exducer = 68mm
Evolution 6
p/n = 49178-01550
p/n = 49178-01560
Inducer = 48.3mm
Exducer = 68mm
p/n = 49178-01570
p/n = 49178-01560
Inducer = 48.3mm
Exducer = 68mm
Inducer = 49.3mm
Exducer = 65mm
Evolution 7
p/n = 49178-01570
p/n = 49178-01580
Inducer = 48.3mm
Exducer = 68mm
Evolution 7 GTA
p/n = 49378-01500
Inducer = 49.3mm
Exducer = 65mm
Evolution 8
p/n = 49378-01510
Inducer = 48.3mm
Exducer = 68mm
TD05HR-16G6-10.5T
p/n = 49378-01560
p/n = 49378-01550
Inducer = 48.3mm
Exducer = 68mm
Evolution 9
p/n = 49378-01580
p/n = 49378-01571
p/n = 49378-01570
Inducer = 48.3mm
Exducer = 68mm
Inducer = 48.3mm
Exducer = 68mm
Evolution X
p/n = 49378-01640
p/n = 49378-01641
Inducer = 47mm
Exducer = 68mm
Inducer = 56mm
Exducer = 49.2mm
Re: Какие турбина на каких Эво стоят в стоке
Фотографии турбины для сравнения 8 (справа) и 9 (слева) эволюции
Вот очень полезный пост http://forum.racing.kz/index.php?showtopic=21605
Сравнение турбы ЭВО 9 (слева) и нашего стока (справа)
Re: Какие турбины на каких Эво стоят в стоке
Турбины Greddy
Сток и Томей и тд05 20G от субаря
max-deikin - Клубень Stage 1
Мужики, кто подскажет в чем именно разница между турбиной 49378-01560 (Evo8MR) и турбиной 49378-01580 (Evo9GSR)?
Xeed - Клубень Stage 2
может тут че есть
http://www.fpak.pt/INFO%20CLUBES/MAN%20 ... e%207B.pdf
Последний раз редактировалось partizan55 15 мар 2013, 11:59, всего редактировалось 1 раз.
Ну как минимум размеры
Dimarik писал(а):Фотографии турбины для сравнения 8 (справа) и 9 (слева) эволюции
partizan55 писал(а):http://www.fpak.pt/INFO%20CLUBES/MAN%20COMISS%20TECN/Manual%20dos%20Comissarios%20Tecnicos%202008%20-%20Parte%207B.pdf
не смог я тут найти ничего об 9ой турбе ...
Dimarik писал(а):Ну как минимум размеры
та одинаковые они вроде ...
Xeed писал(а):Dimarik писал(а):Ну как минимум размеры
Фото выше на пару постов
Где то уже выкладывали, но найти не смог
http://www.mitsu-media.com/showthread.php?t=10279
OEM Part No.
Вот ещё по турбинам http://homepage2.nifty.com/lancer/turbo.htm
Xeed писал(а):Мужики, кто подскажет в чем именно разница между турбиной 49378-01560 (Evo8MR) и турбиной 49378-01580 (Evo9GSR)?
Вот еще тут описана разница в турбинах http://www.evomn.net/forums/showthread. ... rbos-(pics)
что за турбина такая TD05HRA-155G6C-10.5T ?
keurogeo - Клубень Stage 2
Это самая пиздатая из эво-турбин! Титановая крыльчатка. Спулится как тд04, при этом дует 2кг как нех.й петь!
Marshall писал(а):Это самая пиздатая из эво-турбин! Титановая крыльчатка. Спулится как тд04, при этом дует 2кг как нех.й петь!
она с эво -9? нужно тогда добавить ее в список турбин устанавливаемых на эво.
Она там (на картинке) есть Эво 9мр рс.
keurogeo писал(а):что за турбина такая TD05HRA-155G6C-10.5T ?
У меня такая стоит )))
А когда то неоднократно говорили, что больше 1,5 в нее дуть нельзя - развалится
