Hello from Australia!
This website is fantastic! I just wish i could read and write russian (sorry)
Can some of the Guru here please help me?
I have a 2003 Airtrek with 89970017 ECU. I can read ecu and log ok but the definition .xml is no good. I am using the 1.3 tactrix cable.
Can i flash my ECU to 89970010? My ecu is mitsukernalocp and 010 is mitsukernal... is it a problem? I dont want to kill my ECU!
Привет из Австралии!
Этот сайт фантастичен! Я просто хочу, чтобы я мог читать и писать по-русски (извините)
Может ли кто-нибудь из Гуру здесь помочь мне?
У меня есть Airtrek 2003 года с ECU 89970017. Я могу читать ecu и log ok, но определение .xml не подходит. Я использую кабель тактикс 1.3.
Могу ли я зарядить свой ECU до 89970010? Мой ecu - mitsukernalocp, а 010 - mitsukernal ... это проблема? Я не хочу убивать свой ЭКЮ!
89970017 Questions
- OzAirtrek03
Re: 89970017 Questions
Да вроде нет проблем с заливкой 010
You can safely write 80700010 or 89970010 to your ecu.
Flashmethod doesn't tied to firmware id, but to ecu itself.
If you can only download your rom with mitsukernelocp use it also for all other roms. Edit flashmethod in read_evo7 GTA.xml for reading and in corresponding rom xml (80700010.xml, 89970010.xml) for writing.
You can find ecuflash with needed xmls here: viewtopic.php?p=348#p348
Also there are 80700010 roms for typical setups, including one for full stock.
Brilliant - thank you COOLM4N! i will try and report back!
- OzAirtrek03
Success!!
I changed the read method to mitsukernalocp and it flash 89970010 correctly!
Now i can actually start to tune -thankyou!
- OzAirtrek03
Here we go again- let's get it started)))
